power supply board replacement part
i'd like to get a power supply board (flextronics) for my 27" thunderbolt display. are these for sale? are they same is what is in a 27" iMac?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
This should still be under warranty. If it is, I would certainly get the extended AppleCare warranty.
このアンサーは役に立ちましたか?
Hi
Power supply board part numbers are: 661-6048, 661-5543. I found boards available for sale on ebay and maybe available for other apple spares suppliers if you search using the part numbers.
このアンサーは役に立ちましたか?
Will both power supply board with the different part numbers be compatible for a Thunderbolt Display?
The question is still open, are those part numbers interchangeable or: what's the difference?
過去 24時間: 2
過去 7 日: 3
過去 30 日: 22
今までの合計 7,236
7 件のコメント
Hi aaronoehlke. Did you find the power supply board for sale?
SW さんによる
I also need this - it makes a weird noise - and it is coming from the power supply...
Antonkjaer さんによる
Have you got the power supply?
Karsten Bundgaard さんによる
Hi Karsten,
Nope - have you got one in Denmark?
Antonkjaer さんによる
Unfortunatly not!
2件以上のコメントを表示
