メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
他のカテゴリーには当てはまらない製品です。
What model battery is inside?
What type of battery is inside the Robosen Optimus Prime and how do you replace it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
3 件のコメント
Hi! Can you please give some short instructions about how to dismantle legskirt? Tryed for 1 hour with no luck and dont want to break(
さんによる
If you have found a way to solve the problem, and where you ordered a spare battery, I will be very grateful
さんによる
Can you please share what battery you bought to replace the old one and if it worked. Thank you
さんによる
コメントを追加
2件の回答
最も参考になった回答
@rtecbot little did I know this beast even existed. Dang. Quite a price tag. Anyhow, they keep this a bloody secret. Here is a bit of information that I got.
画像
External Photo 5145877Robosen Optimus Prime Internal Photo 5145878
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I wasn't able to tell from the pictures, but would the battery be the same for the Flagship edition? That's the one sold earlier and is several inches taller. Mine no longer holds a charge and I am hoping against hope that there's batteries I am replace (and some kind of documentation on how to do so).
さんによる
@bakersysadmin I couldn't even guess on that one. I assume that this battery most likely will be the same. If you find a way to the battery, let us know. Take lots of pictures so you can create a guide (iFixit is always willing to help with that as well :-)
さんによる
コメントを追加
The battery is a batterypack an 11,v / 12,6v
1200mah 13,32wh.
Its a battery pack that consists of 3 x 3,7v put together.
Located behind the grill, you have to unscrew it with four screw on the backside of the grill, but to get to two of the screw youll ned to dismante "legskirt" and the legs/servos from the hip. The battery is set up with a quickconnector and is really bad and 100%chinese.. mine wouldnt charge and the batterypack was even bloated! Straight out of the box! Shipping to my location is 500usd, so i decided to figure the $@$* out for my self..
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
さんによる
コメントを追加
回答を追加する
Ronnie Chai さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 39
今までの合計 1,919
