My camera is not working
my laptop camera is not working but in device manager it shows cameras in devices and the driver is Acer FHD user Facing but when I open the camera app it says no camera are attached
Well I will suggest you to do: go into Settings > Bluetooth & Devices > Cameras > Under Connected Cameras, click on your Camera > Click Enable.
このアンサーは役に立ちましたか?
Restrat laptop and check privcay setting to ensure cam access is enabled.
verify that the camera is enabled and functioning in different apps.
Check bios settings and physical connections
Perform a system scan with sfc /scannow if needed.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 26
今までの合計 404
