メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2022年9月に発売された第2世代Apple Watch SEの修理、分解、トラブルシューティング情報。
Unresponsive Touch Screen for Apple Watch SE 2
Anyone here experienced the touch screen being unable to respond to touch input? I use my apple watch almost daily for workouts and maybe sweat has probably gotten into. Could this cause the unresponsive touch screen? Thanks.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
Its possible the seal broke down and the sweat found its way into the back side of the crystal which is where the OLED and touch sensor sit. Ifixit only has the 44mm still in stock Apple Watch (44 mm SE 2) Screen. Its a bit of a process to take off and you still need to get the seal gasket as well. Here's a reference on the process as we don't have an SE 2 guide but its mostly the same Apple Watch (44 mm SE 2) Screen.
You may want to just get a new watch as its likely the battery is on it last legs as just the parts alone is close to the same costs of a new watch.
Replace an OLED screen compatible with 44 mm SE 2 Apple Watch smartwatches model A2723, A2727, A2724, A2856.の画像
製品
$149.99
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Arjay Umawing さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 20
今までの合計 239
