メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Compatible Touchpad Replacement Parts
I am trying to replace the touchpad as it has a constant Error code 10 when trying to connect, through reinstalling the drivers and updating them it doesn't work. Are there compatible touchpads from other laptops that I can use in place of it? I am having trouble finding a replacement touchpad which I believe is the problem.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @kylew87212
Check if there's a part number on the touchpad and search online for the number to find suppliers.
Here's the hardware maintenance manual for the laptop that may help.
Go to p.59-p.60 to view the procedure to remove the upper case with keyboard assembly, so that you can see if there is a part number on the touchpad.
The parts list for the model, doesn't show the touchpad as a separate item as it is most probably included as part of the C-cover with keyboard assembly. Click on Machine Type > Select Commodity to see all the available parts and their part numbers.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I looked up the part with the stickers on the back it looks like the vendor was CNY the P/N: was PK37B01FL00 P531003290000AEJ
it came up with nothing but I am probably going to look into what you mentioned because it would get me the part but the keyboard would be a waste unless someone brings me a broken keyboard.
さんによる
コメントを追加
回答を追加する
Kyle W さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 12
今までの合計 322
