メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Power Mac G4のMirrored Drive Doorsモデルです。
FireWire Target Disk Mode Not Working?
Hello, recently, i bought a firewire 400 cable to connect my iBook G3 to my PowerMac G4 MDD, to transfer files too large to for my flash drive. The cable finally arrived today, and I set the iBook to restart into target disk mode in system preferences, and connected the cable to both computers, it rebooted, and showed a yellow firewire logo, on a blue screen. However, My Powermac G4 never found the iBook, I tried connecting the cable to both of the firewire ports on the Logic board, and the other two on my expansion card, but nothing, it couldn't find the iBook, not even in disk utility. I also tried putting the PowerMac into Target disk mode, and the iBook couldn't reconize it. I'm not too farmilier as to how to use target disk mode, but it seems i did everything right. I also tried removing the expansion card in the PMG4, but still nothing, I don't have any other devices to test the cable. I also have a couple other cards in the powermac (SCSI, Sound) should I remove those as well? Did I forget anything to get this too work?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
What Mac OS are you using on the computer you are trying to use as target?
さんによる 共有
コメントを追加
1 件の回答
ベストアンサー
Try starting the PowerBook up holding the "T" key instead of using system preferences. Boot the PowerBook first then the MDD.
このアンサーは役に立ちましたか?
スコア 4
7 件のコメント:
I tried that, but it still does this.
さんによる 共有
The cable has to be suspect. What you did should work.
さんによる 共有
Ok, thanks. i might test it with a meter to see if it is messed up.
さんによる 共有
Remember the machine that is trying to be used in target mode must be Mac OS X
さんによる 共有
The cable was bad, I just decided to pay an arm and a leg at Best Buy, and get a new one and now it works.
さんによる 共有
2件以上のコメントを表示
コメントを追加
回答を追加する
Chris Green さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 31
今までの合計 6,399
