メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nintendo Switch向けに公式ライセンスを取得したJoy-Conの代替品。2019年9月に発売。モデル番号NSW-182およびNSW-182Uで識別可能。
Left stick not taking up inputs
So for some reason whenever I hold up with the left stick on my split pad pro, it just stops taking the input for a split second repeatedly. So for a few moments I can have the input be fine, but then it just stops for a split second. Does anyone know why this happens and how I can fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
This sounds like the same kind of issue you would see with joystick drift. Please see my answer below for that repair.
Drift is a common problem with all joysticks. The best way to solve that problem with with a joystick replacement. The Hori Split Pro appears to be compatible with Xbox joystick replacements like can be found anywhere you search for "xbox joystick replacement". For example: https://a.co/d/5AmYLY1
The existing joystick would need to be removed/unsoldered and replaced with a new joystick. This is a common repair for any controller with a joystick. Search YouTube for thousands of videos on how to do it.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
CJ BlueThunder さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 16
今までの合計 331
