Screen Compatability Between Models 2009-2012
I have 3x MacBook Pro 13" Unibody Mid 2012 (2.5 Ghz Models)
To give some background, these were are all suffering from different issues being either:
(Unit A) 2012 A1278 Screen Display Burn GPU Fix? an internal GPU problem
- External Display is OK..
(Unit B) Fan spin, DVD drive sound but no boot chime, black screen.
(Unit C) A totally dead water damaged donor late 2011 unit MBP A1278 2012 No life dead......
(Unit D) MacBook Pro 13" Unibody Late 2011 - Wter damaged - Donor unit.
1x MacBook Pro 13" Unibody Mid 2009 (Unit E) which had the Stage light effect, external works fine but it was working fine with a new screen & cable albeit now with a track pad that has no click function that will be replaced with a new TP & cable or a donor from one of the above. How to fix a Trackpad with no click function? (2009-2015))
I know that the screen connectors are different between models, but being the genius I am I have mixed up their respective screens in testing them on some of the models mentioned above, and now all of them are not booting, only a spinning fan....
My guess is one of the 3 2012 screens or the mixed up 2011 has some shorted cable and has likely affected these units... (1 new LCD & 2012 Cable, 2 previously working & 1 2012 with backlight staining) The LCD connectors all look the same and fit without any fuss)
So, would a faulty or damaged connector cause all this mess? And if so, what would be the 1st place to check? I am still unable as yet to get a decent microscope to post any images of the circuit boards....
There is a blown fuse on one of the 2012 models (Unit B). Likely caused if I forgot to disconnect the battery when changing screens. I have a 2011 A1278 that I can get the replacement from, can anyone tell me which one to take as they are in what appears to be slightly different positions or any small fuse with the "P" in it?
この質問は役に立ちましたか?
6 件のコメント
@livfe what is the 820 logicboard number for the 2011 donor board and what is the 820 number for the 2012 board. Where on the 2011 board do you see the component? It is always better to post images of your boards and not similar images from youtube etc. since even subtle difference can be important. Also, when dealing with logicboard components, you do want to always reference the 820 number of the board instead of the computer model. It makes things a lot easier.
oldturkey03 さんによる
@oldturkey03 The image from the video is the same as the 2012 board.
2011- MBP "Core i5" 2.4 13" Late 2011 2.4 GHz Core i5 (I5-2435M)
Serial Number C02GFMLADV13 - EMC 2555 - 820-2936-B
https://everymac.com/systems/apple/macbo...
2012 - MBP "Core i5" 2.5 13" Mid 2012 2.5 GHz Core i5
Serial Number C1MJJDAFDTY3 - EMC 2554 - 820-3115-B
livfe さんによる
@oldturkey03 So the one with the "P" is the 3amp 32V fuses in a 0603 package correct? I guess the MB Air 2013 board didn't have the same either :( I will look at the 2011 board again and see if it is there, this 2011 board is a bit grubby but my only option. I will look for where I can find this fuse.... cheers!
livfe さんによる
@livfe the MB Air 2013 board has one. Image of the location is posted. Let me know when you find it on the board :-)
oldturkey03 さんによる
@oldturkey03 They are not there, one was already used to fix the same issue on a MB Air, the other looks lost from the guy who totally messed up and ruined the other 11" board. My only hope is the 820-2936-B 201 board if you can point to it on there I hope it is still present.
Update: One 11" board still has this fuse, I really need my Michael Scope to see this it is so small.... but it is there!
livfe さんによる
1以上のコメントを表示
