メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
9月22日に発売されたアップルの "小型 "フラッグシップスマートフォン2023の修理、分解、トラブルシューティング情報。6.1インチProMotion OLEDディスプレイ、トリプルレンズ背面カメラシステム、5Gを搭載。iPhone 14 Proの後継モデル。
iPhone 15pro Non-Camera Modification
Hi,
I'm thinking of removing the camera from my current iphone 15 pro, cutting the back cover out of a flat sheet metal or titanium without camera protrusions and making it camera-less,
Can anyone who is a cell phone repairman etc. tell me what error do I get when I disconnect the camera from the motherboard in the iphone family and turn on the phone?
Does it give an error on the first startup and pass or does it give a system warning like camera is broken etc.?
or even worse, does it not boot at all?
Thank you.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I would consider myself an etc. So here's my take.
Believe it or not removing the camera is probably a non- issue. You'll probably get some warnings about the camera not being present, but those can be ignored. Replacing your back panel, however might come with some less fun side effects.
  1. No flashlight or wireless charging. They're part of the back glass assembly. And without the camera, the flashlight probably won't work anyway due to the way that circuit works.
  2. Removing the back glass is highly likely to generate an issue where the phone will reboot every few minutes. There is a sensor in the flex cable on the back glass that the phone is expecting check ins from. And if they are not present, it will just reboot (hoping I assume, it will be available after the reboot). Which might make your phone much less usable.
There are probably ways around the second item if you can move the wireless charge coil and all the bits attached to that cable to the new back panel. But that can be a tricky endeavor. And in the iPhone 14 and 14 Plus, where the back panel was redesigned, the original parts are needed to prevent the loop since there is some parts pairing at play. I haven't had an opportunity to check this yet, but I would fully expect it to do this on 15 series as well.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Michael Wick さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 19
過去 30 日: 137
今までの合計 4,383
