メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Samsung Gear VR(モデル番号:SM-R323NBKAXAR)は2016年に発売されました。このヘッドセットに対応しているデバイスは、Galaxy S7、Galaxy S7 edge、Galaxy Note5、Galaxy S6、Galaxy S6 edge、Galaxy S6 edge+です。このデバイスには伸縮性のあるヘッドストラップとmicro-USBコネクタが付属しており、ワイヤレスコントローラーは別売りです。
Unable to install software on phone
Recently picked up a 2016 Samsung Gear VR to mess with, and I am unable to make it work. First tried it with an S7 Edge (running Android 8) and as soon as it tries to install all the Oculus related software, it runs into a "network error" and fails to install the software. Then tried it with my Note 5 (running Android 7) and ran into the exact same issue. These phones should be compatible, so there's no obvious reason this error should be occurring. Any advice above "try a different network", "disable VPN", "do a software update" or any common troubleshooting methods would be greatly appreciated, as I've tried everything commonly suggested online and it hasn't worked. Thanks!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Follow the instructions here:
https://gearvr.net/unbrick
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
This worked perfectly! Unfortunately now I'm unable to sign into the Oculus app, and I'm either told "Your Facebook session has expired or is invalid. Please log in to Facebook again." Or if I try other sign in methods I'm unable to continue due to some error. Is there any way to fix this?
さんによる
You can only sign into the Gear VR with a Meta account, that used to be an Oculus account, that is linked to Facebook.
If your account matches these criteria, sign into Facebook using the Facebook app, then switch back to the Gear VR and select "Sign in using Facebook".
New Meta accounts won't work.
さんによる
コメントを追加
Suppose I don't have meta account what can I do to run library shop oculus 😭 😭 😭 or any way to install all apps that available on shop manually
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
To run apps without a Meta Account, I found it easiest to use a free APK called Gala Launcher, which is a 3rd party way to launch Gear VR apps. You can find APKs for GearVR apps on https://vault.gearvr.net/product-categor... that can be downloaded and installed like any other APK. (Just make sure to allow 3rd party downloads/installs in your device's settings) Once you install some APKs, they will show up in Gala Launcher, where you can easily open them.
さんによる
コメントを追加
回答を追加する
Michael Taylor さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 17
過去 30 日: 100
今までの合計 4,272
