メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Dell Optiplex 790 修理ガイド
Blue screen error problem due to RAM
Blue Screen error problem due to RAM
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Hi @prayag57802,
Did you change/increase the memory?
If so what type and how much memory did you try to install?
Also if you added more memory, does the PC work OK with the original memory that was installed?
さんによる 共有
コメントを追加
1 件の回答
@prayag57802 since you are certain this is caused by a bad RAM module, it is time to change it. Of course, you can also try and clean teh contacts first. I use a pencil eraser to clean the contacts. Also, inspect the RAM slots on your motherboard to make sure that there are no bend or corroded pins etc.
To work on your computer use the Dell OptiPlex 790 Desktop Owner's Manual which essentially is the service manual. Now, if you are just guessing that this is a RAM error, then you have to give us more information about what your computer is doing and what you have tried.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Prayag さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 14
今までの合計 303
