Speaker sound is buzzing
Why the sound of speaker is byzzing
Likely the speaker diagram is torn or sand has collected on it. Best to just replace the speaker/s.
このアンサーは役に立ちましたか?
@ibrarmarwat could be an issue with teh grounding for whatever speaker you have connected. Try a different speaker. The other thing you want to try is to reinstall the proper driver for the audio. If none of that makes a difference you could try a new speaker assembly. To work on it use the HP Probook 4530s Maintenance And Service Guide Page 71 will tell you the part number and how to replace it.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 4
過去 30 日: 4
今までの合計 38
Hi @ibrarmarwat
What is the sound like when using headphones connected to the laptop?
Is it also a buzzing sound?
jayeff さんによる
