Replaced battery says "UNAUTHENTIC BATTERY DETECTED" How do I stop it?
After replacing the battery, Windows gives a popup
How do I stop it?
There are a number of posts about this. Do an internet search for "work around for unauthentic battery detected".
このアンサーは役に立ちましたか?
I tried that, almost all the results say ignore it, or try the following steps which do not work.
"1. Force the device to shut down and restart
Press and hold down the power button until your Surface shuts down and restarts and you see the Windows logo screen (about 20 seconds), then release the power button.
2. Check Windows Updates
Go to Settings >> Update and Security >> Windows updates >> Check for updates
3. Run Surface Diagnostic Toolkit
See: Fix common Surface problems using the Surface Diagnostic Toolkit (microsoft.com)
4. Remove and reinstall battery driver.
From Device Manager, expand the Batteries category.
Double-tap or double-click Microsoft ACPI-Compliant Control Method Battery, select the Driver tab, and select Uninstall > OK. Then restart your device."
The complicating factor is that there are many versions of the "Surface Diagnostic Toolkit". You need to use the version intended for Commercial Repairs - which is available as a ZIP over here: https://www.microsoft.com/en-us/download...
When you run it, also make sure to choose 'Repair' instead of 'Diagnostic'. Then you will have the option to perform a Battery Verification. It will try to contact Microsoft servers to authenticate the new battery.
このアンサーは役に立ちましたか?
過去 24時間: 4
過去 7 日: 20
過去 30 日: 65
今までの合計 65
