メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Google Pixel 7aは、Pixel 7シリーズの予算重視モデルです。2023年5月に発売されたPixel 7aは、顔認証、8 GBのRAM、大幅にアップグレードされたカメラ、ワイヤレス充電を備え、Pixel 6aから改良されています。
Screen adhesive re-use
Just completed a glass/screen repair on a Pixel 7a, but got a smudge on the front camera lens during the process. Sadly, didn't notice until after reassembly was complete. Can I re-open the front, clean the lens, and re-close without replacing the perimeter adhesive, or do I need to clean up and use new glue?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Thanks folks, for the minimal cost of new screen adhesive, it's worth the reassurance that it'll be properly sealed.
さんによる
コメントを追加
2件の回答
ベストアンサー
I'd say it depends on how well the glass comes off. I had an iPhone X that I had just finished working on but banged my head on the table when I realized I'd forgotten to reprogram the True Tone data. So I opened it back up and found that the precut adhesive had stuck on the phone so it was still completely intact and undamaged. That being the case, I decided to reuse it and haven't seen any problem as a result.
So my take on this as it applies to you is, if the display comes off cleanly and doesn't tear or stretch the precut adhesive, you can probably get away with reusing it. If it sticks partly to the screen or tears / stretches when you get the screen off, then it's time to replace it.
One thing you might do when you put the phone back together is to reheat the adhesive once the screen is on, then place it face down with some weight on it. That'll soften the adhesive and the weight will help seal it. Hopefully that'll help compensate for not using a new sheet of adhesive. I usually go over the phone for about 3 minutes with a hair dryer, then I have a motorcycle battery I set on it for a half hour or so.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
You could, But I would highly recommend not to
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Not nay-saying your answer, I'm genuinely curious: voice of experience, or theoretical problem potential?
さんによる
There’s a potential problem
さんによる
コメントを追加
回答を追加する
Frudougy さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 35
今までの合計 1,288
