メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
多くのPackard Bell製コンピュータで使用されていた4X4デスクトップケースです。フロントにある2つの5.25インチドライブベイで簡単に識別できます。
operating system not found?
operating system not found ?? i have checked all of the drives sepearttly, they seem to work.. but the 1994 packard bell says operating system not found. i have tired to boot from a floppy, and it tells me to remove disk and continue.. then i get diddo operating system not found, i am stumped..
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
i have tried to reset things in the bios, and it perfers to load defaults, i had upgraded the dead battery, so it keeps current time,,
さんによる 共有
Hi @gerryfranc26930
Intrigued by your question as I've never heard of a Dido OS if this is what you mean.
If it is then looking at this it seems that it is a program designed to work on Windows (or Linux) and not a separate bootable OS but maybe I misinterpreted it.
さんによる 共有
コメントを追加
2件の回答
May be the os were currepted, try to install os again. It may fix the issue
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hey! Ah, the nostalgia of a 1994 Packard Bell! I remember having a similar issue with an old PC I was trying to revive. It can be super frustrating when it keeps saying "operating system not found."
One thing that worked for me was checking the BIOS settings to make sure it was set to boot from the correct drive. Sometimes, these old systems can reset their boot order for no apparent reason. Also, double-check if the hard drive connections are secure.
When I was troubleshooting my old machine, I stumbled upon some great advice on operatingsystems. They had some tips for dealing with vintage hardware issues that were surprisingly helpful.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Gerry Franco Roberts さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 20
今までの合計 389
