Display flickering on the lap screen
Top side display flickering occurs
@ashiljames connect an external monitor to check if that displays properly. If it does then you know the issue is either your display cable or your LCD. Since we can't see your display and going by your description alone, this sound like a bad LCD.
Use the HP Pavilion Gaming 15 Maintenance And Service Guide to work on your laptop. Page 49 shows you how to work on the display assembly. Check the display cable for any shaved wires near the area where it passes through the hinges etc.
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 3
過去 30 日: 15
今までの合計 229
My hp Pavillion gaming laptop has started flickering horizontal flickering are seen and I want it to be resolved and I have exam in few days
Mohammad Abdul Rahman さんによる
