メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2017年発売の自動原稿送り装置付きドキュメントスキャナー。
Gray zone on one side of Scan
Hello,
I have an ADF scanner that failed to scan documents, from one day to the next.
On one side (the front side), a zone is completely dark gray, about 5cm wide:
画像
The reverse side is okay:
画像
Do you have experience with this kind of device? I haven't disassembled the scanner yet. Viewing some videos, I carefully cleaned the sensor's glass with a paper towel and isopropyl alcohol, with no luck: nothing changed. I suppose the gray zone is too wide to be caused by a dirty glass.
Thank you in advance for your help!
Might be related:
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
Hello,
I suppose the contact image sensor is dead. After 3 hours of trying to disassemble the device, here are the reference parts:
* The first side ("recto"): Brother D00S3P001
* The second side ("verso"): Brother D00S3N001
The second side is the same sensor, with an additional plastic part with 3 screws.
The sensor is a Lite-On DL520-01UHF-D. This is very hard to find and expensive. This part is shared by both the Brother ADS-2700W and the Brother ADS-2200. You can find a Brother ADS-2200 working for less than the sensor itself...
さんによる
コメントを追加
2件の回答
Hi,
Today the price is 56,02 euros on Alibaba.
Not so expensive, nor difficult
Done quite the same for a Canoscan a few months ago.
Here's the link to download the service manual for your scanner
Artefil
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi,
I didn't find the part on Alibaba. Ultimately, I found the same scanner for parts in the USA that someone could bring me for $40. It had a broken spring that I extracted from my scanner and was running again. It was easier to proceed this way and I didn't have to search for how to calibrate the sensors. Plus, I have some additional spare parts now.
Next time I buy one of these machines, I will make sure that many are sold in my country, it will be easier to look for parts.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Antoine Merino さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 763
