Changing front bumper out
Replacing front bumper, thanks
@simon52118 these don't have much of a bumper behind the cover. You'd be more looking at the radiator grill. Anyhow, this from the service manual 2014 to present:
1. Front bumper cover
2. Front bumper side bracket
Replacement
1.Loosen the front bumper upper mounting clips.
2. Loosen the front bumper lower mounting clips.
3. After loosening the front bumper (A) side's mounting clips and screw, then disconnect the side's.
4. Disconnect the front bumper main connector (A).
5.Remove the front bumper cover (A).
6. Install in the reverse order of removal.
If this is not the right model, then you need to let us know the exact year for your Sonata!
このアンサーは役に立ちましたか?
過去 24時間: 5
過去 7 日: 11
過去 30 日: 38
今までの合計 697
2 件のコメント
Hi @simon52118,
What is the year model of the vehicle?
jayeff さんによる 共有
Also, are you referring to the metal bumper itself, or just the bumper cover that goes over it?
Jerry Wheeler さんによる 共有
