メインコンテンツにスキップ
2015年9月25日にAppleから発売されたiPhone 6Sの修理情報とガイドです。モデル A1688、A1633。
2696回答 すべてを表示
Screen has fading vertical lines
My iphone 6s fell screen down about a week ago, now the screen has fading vertical lines and an unresponsive screen sometimes, and sometimes it works. If I shut off the screen the lines are cleared away but come back. When the screen is responsive, if I lock the phone and open it back up, it is unresponsive again. I've tried restarting, force restarting, there are no more updates for the phone due to its age. Looking for a possible fix for this issue
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
This looks like the connections to, or an internal component of the LCD & Digitizer display has been damaged, and is likely the cause,
there is a iFixit guide on how to replace the screen, and parts available: iPhone 6s LCDとデジタイザの交換
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
I had this issue when I dropped my iphone also, most likely you are going to need a new screen. As @conorbone said follow this guide to find out what you should do: iPhone 6s LCDとデジタイザの交換 .
I also had this issue when I swapped in a display (turned out to be faulty) and the connector was not connected properly resulting in a bad connection and similar looking lines.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Scott S さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 20
