How to replace my broken charging port?
The charging port broke off inside the speaker.
This "The charging port broke off inside the speaker." doesn't exactly define your problem. It can be interpreted a couple of ways.
One way, says you must figure out how to get the broken piece of the plug out of your charging socket. The other way says you must open up your unit and replace the charging socket.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 13
今までの合計 13
We'll need to know a bit more here to help. What model of Bluetooth speaker do you have? Or at the very least, what does the charge port look like?
Alisha C さんによる
