Why is my laptop not charging when I plug it in?
My laptop is not charging when I plug it in. I've tried plugging in and out the charging port, and I tested the charger with another laptop. There's no visible damage on the charging port either, it seems perfectly fine. The light isn't lighting up on the charger, even though it does on the other one. What could be wrong?
Update (05/04/24)
It ran out of battery ages ago. Also, the display wire, hinges and clutch cover are broken.
@hamzas Is it fair to assume it is not starting up when connect to a Magsafe power adapter?
oldturkey03 さんによる
@oldturkey03 yes, it doesn't start up when connected to a magsafe power connector
Hamza Safdari さんによる
@hamzas So three is absolutely no light (no Amber or no Green light). No sign of life when you plug it in etc.? The MBA appears to be totally "dead"?
oldturkey03 さんによる
@oldturkey03 yes
Hamza Safdari さんによる
@hamzas let's see if a different Magsafe will work for you :-) keeping our fingers crossed but still having some major doubts. There just seem to be a lot going on with your MBA
oldturkey03 さんによる
9件以上のコメントを表示
