メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
ToshibaのSatelliteノートパソコン、C650シリーズの修理ガイドとサポート情報。
Why the touchpad is not working
The touchpad is suddenly stopped
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
Why is my mouse pad not working
さんによる
@duanenelso51585 what do you consider the mouse pad to be? The computer really only has a touch pad.......
さんによる
コメントを追加
2件の回答
最も参考になった回答
You probably accidentally pressed a one of FN F1-F12 combination. A list of Toshiba FN keys that allow you to activate a range of features on your laptop listed below. The one you want is probably "Fn-F9":
  1. Press "Fn-Esc" to mute or unmute your computer's speakers.
  2. Press "Fn-F1" to lock your laptop. When you lock your laptop, only the user password you have set will allow anyone to access it.
  3. Press "Fn-F2" to display all power saving options available for your laptop. For example, you can turn off your optical drive to save battery life.
  4. Press "Fn-F3" to activate the Instant Standby mode. This mode powers down your computer except for the memory, allowing you to quickly turn on the computer the next time you need it. Instant Standby allows your computer to stay on for up to 30 hours.
  5. Press "Fn-F4" to activate the Hibernation mode. This mode is similar to Instant Standby except the power can last for 26 days; however, it takes longer to power on the computer.
  6. Press "Fn-F5" to cycle through your display options.
  7. Press "Fn-F6" to decrease the brightness of your monitor. Each time you press these keys, you decrease the brightness.
  8. Press "Fn-F7" to increase the brightness of your monitor. Each time you press these keys, you increase the brightness.
  9. Press "Fn-F8" to change your computer's wireless connection from Wi-Fi to Bluetooth and back again.
  10. Press "Fn-F9" to disable the mouse touchpad. Press the buttons again to enable it.
  11. Press "Fn-F10" to disable the arrow pad. Press the buttons again to enable it.
  12. Press "Fn-F11" together to disable the mouse number pad. Press the buttons again to enable it.
  13. Press "Fn-F12" together to zoom in your screen. Press the buttons again to zoom out.
  14. Press "Fn-Spacebar" to change the resolution of your monitor. Each time you press these buttons, the resolution changes.
I hope that helps.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
@beletetenaw you are not telling us what you have checked and if this just happened all of a sudden or if anything preceded this.
first check to make sure that the Touchpad is enabled. To re-enable your touchpad:
On your laptop keyboard, press the Fn key and the F9 key at the same time.
Now check to see if it is enabled.
If that does not work you want to make sure that you have the proper driver. Since we don't know which OS you have (Windows?) it's difficult to tell you which driver you have to get. Definitely update the driver according to your OS.
Now, if none of that works, you may just have a bad touch pad. If so, time to replace it. Since iFixit doesn't yet have a guide for that, use something like this video
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Belete Tenaw さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 30
今までの合計 695
