メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1419 / Late 2012 / 2.9 & 3.2 GHz Core i5または3.4 GHz Core i7プロセッサ、ID iMac13,2
How is xeon support?
Are xeons supported? I have seen people swap in xeons in the 2011 models so i would assume 2012 should be the same but i have not come across anyone who has done this.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Swapped in a Xeon E3-1275 v2 i got for 23 bucks off ebay. Everything works fine and saved a bit of beer money. Also popped in a msata ssd with a 7+17 converter and booting off that nicely as well.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The issue is the generation of Intel chips. I really don’t see any benefit if you already have an i7 chip and if you have an i5 then getting to an i7 would be what I would do. Keep in mind the needed micro code is held in the EFI so only the CPU series Apple has used is within the EFI.
Between the xenon being a Broadwell series as well as most have a higher TDP which would be to high for the system you really can’t use them.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
This socket only supports Ivy and sandybridge anyways and the ones im looking at maintain the same tdp.
Also its a bit cheaper, chips are basically the same but i dont see a point paying an extra 10-15 bucks for essentially a name change.
In addition xeons are not present in the 2011 imac lineup either but still maintain compatibility.
I guess i will update this thread if it worked or not when i test it.
さんによる
incorrect, the xeon equivalent of the i7 3770 is a bit cheaper at my time of purchase and maintains the same tdp as its consumer version. Sandybridge and ivybridge xeons exist.
さんによる
コメントを追加
回答を追加する
Ed Chen さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 10
過去 30 日: 26
今までの合計 420
