メインコンテンツにスキップ
Appleが設計したM3 SoCでリフレッシュされた、2023年11月発売の新しいベースモデル14インチMacBook Proの修理ガイドと分解情報。M2を搭載した13インチTouch Bar MacBook Proの後継モデル。
4回答 すべてを表示
How can I open up the m3 MacBook Pro base model(That I LOVE SO MUCH!)
So I made a post about something, and I need to open it up and send picures to them on my post. So I wanna know how to open up the MacBook without, using a spudger. Or a thin opening pick. And I want detailed pictures. I have a heavy/meduim duty suction cup. and I have a sort of a bit thick opening pick.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
Here is a little guide on how to do it, also a guitar pick will work perfectly fine if you have that
Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Lower Case Replacement
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I''m having this too. But i dont have a guitar pick or any pick. Can you please give a more easier less resourceful guide?
さんによる
Ok let's start with what you have the could be of help here
You could just unscrew it and use your giant suction cup and a (small steak) knife to do it
Do you have a screw driver that can unscrew the ones in your macbook
さんによる
@altname - Be careful! As you don't want any metal tools near the logic board (shorting out) and a knife pushed in to far can cut into the battery or cause other damage. Best to find a guitar pick, this maybe a bit much for you to take on without hurting your system.
If you just want a picture iFixit doesn't have the M3 version, but here is images of the M1 & M2 systems M1-M2-interior A lot less work and less likely to damage something in the process! You might find some other sites offer the M3.
さんによる
コメントを追加
@vjnfd3gkfrelm9b besides what you want, we would need you to tell us what you have available. It will be so much easier if you tell us what you have available insead of us guessing. Open your kitchen "junk drawer " and pull out any wooden and plastic "gadgets" and tools you can find, then take a picture of those. Post that with your question. Based on that picture we can always come up with something inventive to help you out. Half of a wooden clothespin comes to mind :-) A file or some sandpaper to shape it and voila, here is your wooden, non-marring spudger
iFixitでの質問に画像を追加する方法
It's pretty minimalistic since all you will need is a pentalobe screwdriver, a suction cup and a non-marring pry tool. MacBook Pro (14 Inch And 16 Inch) Nov23
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
218940-1 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 58
今までの合計 58
