メインコンテンツにスキップ
Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Lower Case Replacement
必要な工具と部品
  1. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Lower Case Replacement, Unfasten the lower case: 手順 1、 2の画像 1 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Lower Case Replacement, Unfasten the lower case: 手順 1、 2の画像 2
    この手順で使用する道具:
    FixMat
    $36.95
    購入する
    • Completely power off and unplug your MacBook Pro before you start. Close the screen and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.3 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Lower Case Replacement, Unclip the lower case: 手順 2、 2の画像 1 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Lower Case Replacement, Unclip the lower case: 手順 2、 2の画像 2
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  3. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Lower Case Replacement, Release the right clips: 手順 3、 3の画像 1 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Lower Case Replacement, Release the right clips: 手順 3、 3の画像 2 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Lower Case Replacement, Release the right clips: 手順 3、 3の画像 3
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  4. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Lower Case Replacement, Release the left clips: 手順 4、 3の画像 1 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Lower Case Replacement, Release the left clips: 手順 4、 3の画像 2 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Lower Case Replacement, Release the left clips: 手順 4、 3の画像 3
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  5. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Lower Case Replacement, Release the sliding clips: 手順 5、 3の画像 1 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Lower Case Replacement, Release the sliding clips: 手順 5、 3の画像 2 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Lower Case Replacement, Release the sliding clips: 手順 5、 3の画像 3
    • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
    • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
  6. Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Lower Case Replacement, Remove the lower case: 手順 6、 3の画像 1 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Lower Case Replacement, Remove the lower case: 手順 6、 3の画像 2 Macbook Pro 14" Late 2023 (M3 Pro and M3 Max) Lower Case Replacement, Remove the lower case: 手順 6、 3の画像 3
    • Remove the lower case.
    • To reinstall the lower case:
    • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
    • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
    • You'll hear and feel each clip snap into place.
終わりに
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" Late 2023 (M3 Pro and M3 Max) Answers community for help.
Alex Diaz-Kokaisl
メンバー登録日: 01/16/22
125,206 ポイント
582のガイドは作成済み
チーム
iFixit iFixit人のメンバー
Staff
136 メンバー
17,442のガイドは作成済み
0 件のコメント
コメントを追加
統計データ:
過去 24時間: 9
過去 7 日: 26
過去 30 日: 104
今までの合計 488
