メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル A1347。2011年7月21日発売。Core i5またはCore i7プロセッサ搭載。Thunderboltポート搭載。Mac mini Server構成でも使用されているモデルです。
Stuck in loop boot and will only safe boot
First I tried to restore using mac OS recovery which did not complete the install. Due to posable expired certificate issue.
So I download High Sierra and made a bootable installer. Formatted the SSD and ran the installation, this did not complete the installation process. But then enters a boot loop, boot runs then restarts to about 3/4 off the grey install screen, then reboots again.
Then on the start of a reboot pressed the shift and managed to complete the installation process in safe mode.
Now it is continuously still stuck in loop boot. It starts to 3/4 grey startup screen and restart again.
But you can force it into safe mode. Also now the start chime now has stoped working.
I have tried many times now and have lost my way forward.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
To get around the expired Cert you'll need to use a second Mac system to download the OS installer file and then setup a USB thumb drive as a bootable OS installer (don't forget to first format the USB drive to GUID-Journaled) Goto this cute to get the OS file How to download and install macOS then follow this guide Create a bootable installer for macOS.
See if that gets you going, good luck! You may need a new drive.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
john さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 7
今までの合計 262
