メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Ghost touch on phone
How to fix a ghost touch on my phone screen,? Any one ?
When I use my phone it change by itself like logging me out or clicking back arrow or writing wrong words things like that. It's very annoying and feel frustrated when using my phone.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
2 件のコメント
I appreciate your time and possible solution to this matter but I think it's time to get new phone. Thanks.
さんによる
My phone is blinking off and on it's shutting down it's frequently freezing and I have to I can't turn it off I can't do anything with it it's literally like freezes my screen and I can't load up anything I can't change the app I can't do nothing I've cleaned out that everything I have had to do and every time I do I can't get on to my Gmail accounts my apps that I put on my phone I can't get on and anything and it's very aggravating it's not sinking right nothing
さんによる
コメントを追加
2件の回答
ベストアンサー
This is a common problem with some phones— ghost touch is usually caused by a touchscreen malfunctioning due to physical problems, such as a low quality digitizer, a damaged screen, dirt under the screen, or water damage. My recommendation is that you should get your phone cleaned under the screen (protector) and make sure that there is no dirt left. If that doesn’t work, try resetting. :)
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
You are right in that recommendation or solution to this matter. Thank you.
さんによる
コメントを追加
@grace74377 that is an issue related to a bad display assembly. The digitizer (touchscreen) is malfunctioning ( there are technical reasons for it but too long for here) Replacing the display assembly will fix this.
First make sure you try and remove your screen protector, just in case that is what causes the issues.
Use this guide Motorola Moto G Stylus 5G (2022) スクリーンの交換 to work on it
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
Thank you for your input in this matter, I think the best solution will be buying a new phone. Best regards.
さんによる
コメントを追加
回答を追加する
Grace さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 26
過去 30 日: 105
今までの合計 5,956
