メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Game Boyは1989年4月21日に日本で発売され、続いて1989年7月31日に北米、そして1990年9月28日にヨーロッパで発売されました。大型のグレーのケースとモデル番号DMG-01が特徴です。
Game boy not turning on
I found my daughter’s Game Boy packed away in a bin in the basement. It’s been there for at least 15 years since she moved out. I thought my grandkids would like it. I cleaned the battery area and used new batteries but I can’t get it to turn on. The battery light doesn’t even come on. I called Nintendo and they no longer repair them. Any suggestions?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
@lorimaleko27985 the very first thing you want to do is to clean the battery contacts. Make sure they have not corroded to badly. If those are okay, you will have to disassemble your GB and take a look at the components. You could try and clean it with some isopropyl alcohol (+90%) and carefully check to see if there is anything obviously corroded etc. Until you have it apart, anything will only be a guess. Use Game Boy these guides to help you with taking it apart. Once you have it open, take a couple of well focused pictures and post those with your Question. That way we can see what you see and hopefully guide you further. iFixitでの質問に画像を追加する方法
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thank you. I just ordered a tri-wing screwdriver off Amazon and should receive it in a few days. I’ll let you know how I make out when I have it apart.
さんによる
コメントを追加
回答を追加する
Lori Malekovich Pluta さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 13
今までの合計 227
