メインコンテンツにスキップ
2022年2月25日に発売されたValve製の携帯ゲーム機「Steam Deck」の修理・分解・トラブルシューティング情報です。型番1010で識別されます。
20回答 すべてを表示
Why is my display so Dim?
So basically here is what happened. I started noticing that the screen on my steam deck would start to flicker between super dim to bright very sporadically. I would originally fix this by turning the display brightness all the way up. This would stop it from flickering, but any time I turn the brightness back down it would continue to flicker. I have done all the resets and restarts so I don't believe its software related.
After awhile I started to notice that it was getting worse and the screen would stop flickering and just completely stay dim. Now I do see the screen and I can still manage the steam deck it’s just that the brightness is all the way down and I have no way of increasing it.
Edit:
I have some pictures of the steam decks circuitry and I have not noticed anything obviously unplugged or damaged. Another update to the problem the back light just never comes on now.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
Sounds like it has a problem with the backlight circuitry or similar circuitry.
Update (03/26/24)
@kylewolf26083 Let's keep in mind that I don't have all answers. And even I hope my diagnosis is wrong. If you Follow this guide and check all the connections before we go as drastically as attempting board level repair we might find an easier solution to the problem. Adding pictures to your question as you get into the unit can help other people give a better more accurate diagnosis too.
Steam Deck マザーボードの交換
iFixitでの質問に画像を追加する方法
iFixitの画像
ガイド
難易度:
とても簡単
2 - 5 minutes
Steam Deck マザーボードの画像
ガイド
難易度:
中レベル
1 - 2 hours
このアンサーは役に立ちましたか?
スコア 1
4 件のコメント:
@markusnorstroem Is that Backlight circuitry built into the screen or display? If I put in a new screen/Display will this fix the issue.
さんによる
@kylewolf26083 Unfortunately it usually is on the motherboard side
さんによる
@markusnorstroem Well that stinks I ordered a new screen to try and fix this issue, but I can always return it. I really cant find anything on this issue online and Steam support isn't helping to much. I just need an idea of what I need to replace in this steam deck.
さんによる
@markusnorstroem ok so I have taken the case off and could not observe any obvious broken cables or peices. I made sure that the display cables and other cables were not loose. I also took a look at that chip and couldn’t see that it had any loose pins on it. The Chip looked well soldered to the board.
さんによる
コメントを追加
@markusnorstroem I understand that your previous answer might not be it. I had ordered the screen due to the fact that I didn't think that the Backlight circuitry was on the motherboard. So moving forward do you think I should take some pictures of the mother board? The only thing I would need is the location as to where the backlight circuitry lies on the board.
I also have been debating on the cost difference between getting this one working and a new OLED steam deck, but for now I am focusing on getting this one working.
I also want to say thank you for responding and helping me. So far you have been better than the actual steam support.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
@kylewolf26083 Seems the circuitry you are looking for is marked on the ifixit teardown video at around 5:40 in what looks like a pink outline. Check the connected components from the marked driver IC for damage if nothing is obviously damaged.
https://youtu.be/4T0RZ6ustKQ?si=lEJLkWWu...
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Alright I can check that out and see if I find any obvious issues. After looking up this little Driver I don't see much information online. Is this a very abnormal thing to go bad?
さんによる
What numbers are on it? The driver might not go bad over time but some of the connected circuitry might.
さんによる
@kylewolf26083 The green component on the last picture you added seems like a fuse. have you inspected that?
さんによる
コメントを追加
回答を追加する
Kyle Wolf さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 16
今までの合計 313
