How I can replace my screen
How I can replace my screen in my phone and battery becouse my battery is dead
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi Mateusz,
On your phone, as it is with most Samsung phones, there are two ways to replace the screen. The usual and recommended way is to replace the screen plus the frame as a single assembly vs. replacing the display alone. Markus' video link shows replacing the screen+frame assembly, as does the link I'll provide.
The two methods both have advantages and disadvantages and require different procedures. For the screen+frame method you basically have to gut the phone completely and transfer all of the interior components to the new frame assembly. The phones are actually made in such a way as to facilitate this, so it's not nearly as bad as it would be on something like an iPhone housing swap. For the screen only method, you have to carefully separate the LCD from the display, clean off all the old adhesive, then glue the new screen onto the frame, clamping it securely until the glue dries. Note that the screen+frame assembly is generally only a couple of dollars more expensive than the screen alone, but that difference can easily be eaten up with the need to buy glue as well.
Here's the screen+frame replacement guide for your phone.
Manuales / Samsung Galaxy M11 / Fullscreen - Nadie Me Llama Gallina
The guide is in Spanish but used in conjunction with the Chrome browser's language translation, it is very usable no matter what your native language is.
Replacing the battery is actually part of this procedure, so if you're doing that repair you don't need a separate battery replacement guide. However, if you decide you only need to replace the battery, here's the guide for just doing that.
Manuales / Samsung Galaxy M11 / Battery - Nadie Me Llama Gallina
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 6
過去 30 日: 30
今までの合計 1,000
7 件のコメント
You technically only need to replace the battery. That is however sometimes challenging. Have you damaged the sceen trying to replace the battery since you need the combination of both replaced?
This guide might be of help for changing both parts if both are necessary to change.
https://www.youtube.com/watch?v=AFgh4epK...
Markus Norstrøm さんによる 共有
Want to change combo
Monik gowda さんによる 共有
How to replace screen
VIP BOYS King さんによる 共有
@vipboysking
See the Most Helpful Answer below!
jayeff さんによる 共有
@monikgowda We don't understand what you mean. What part of the phone is a "combo"?
Jerry Wheeler さんによる 共有
2件以上のコメントを表示
