メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
5G EditionのSamsung Galaxy S10スマートフォンを交換部品DIY修理ガイドで修理します。
Blue connection not turning on
When I try to enable my Bluetooth through the status bar or in the settings the nob Icon will not turn on. However my wifi connectivity still works perfectly
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
5 件のコメント
Did this happen after an update?
さんによる
Please see if phone reset helps
さんによる
@oldturkey03 I highly appreciate the feedback, I just tried the Safe mode trick and still had no luck. I now strongly believe that the issue might be hardware related.
さんによる
@markusnorstroem Not necessarily, I used the phone for over a year and a half with the latest update. I believe the issue might be hardware related.
さんによる
@i_am_the_cosmos unfortunately that did not work, I tried a network reset and still had no luck. Thank you for your input
さんによる
コメントを追加
2件の回答
ベストアンサー
@bwalyamataka since your WiFi still works you may have issues on a component level. First you must rule out that this is a software issue.
First start your phone in safe mode. To place it in safe mode, use the Samsung instructions from here Once in Safe mode give it a try and see if it works now. If so, you know that you have a bad 3rd party App on your phone. It will not tell you which one so you will have to delete one after the other until you find the one that causes this issue.
If it does not get better in Safe mode, it is not an App etc. and you can exit safe mode.
Check the Bluetooth firmware version of your phone by dialing ****#2663#*** and see if it shows up properly. ******Anything after that would lead me to having to check the components on the board. Looks like your phone is a SM-G977. There are no free schematics out there but you can can get them through fee-for-service $$
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
@bwalyamataka
Try wiping the cache partition and check if that resolves the problem.
Go to Wipe Cache Partition → Samsung
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Bwalya Mataka さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 24
今までの合計 433
