Windows 7 screen resolution problem
I have an all-in one PC that had 32- bit Windows 7. But once I upgraded to the 64- bit version,the only available screen resolutions were 800x600 and 1024x768. MS-A923
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @pawelc
What resolutions were you getting with Win 7 32-bit?
According to the specifications, the AIO uses onboard video i.e. Intel Media Accelerator 3150 integrated in the Intel D525 CPU.
This only supports resolutions of up to 1366 x 768 for internal LVDS connections.
This is also the native resolution of the AIO display.
Have you got the Win 7 64-bit graphics drivers (example only) installed, to see if you can get to 1366 x 768 resolution?
このアンサーは役に立ちましたか?
@jayeff 800 x 600, 1024 x 768 even though it's widescreen. But it gets stretched out
@pawelc Have you installed the drivers?
@thequacker Yes and it worked!
過去 24時間: 0
過去 7 日: 10
過去 30 日: 47
今までの合計 787
2 件のコメント
@pawelc you may need the 64bit display driver.
oldturkey03 さんによる 共有
It might just be simpler to upgrade to Windows 10? It handles drivers much better than W7.
mike さんによる 共有
