メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2019年に発売されたASUS ZenBook Pro Duo UX581GVは、メインの15インチOLEDタッチスクリーンに加え、キーボードのすぐ上にセカンダリタッチスクリーンを搭載したユニークなノートパソコンです。
Do I need to replace my screen?
My laptop developed this bright area across the entire screen.
画像
Not sure if I need to replace the video card or the screen?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
2 件のコメント
Have the same issue since Friday - did you manage to resolve it?
Note it is only on the main screen, I have 3 other UHD screens attached with no issue.
Thanks,
W.
さんによる 共有
Hello. I also have the same issue. I don't know if I should buy a replacement screen from Amazon and install it. I'm afraid the quality won't be the same as the original, what do you think ?
さんによる 共有
コメントを追加
1 件の回答
ベストアンサー
@tanyarey it does not look like a video issue but more like a display issue. One thing to try is to attach an external monitor. If that displays the same line, it's your GPU circuitry (video circuit is built into the motherboard, it does not have a separate video card). If the external monitor does not show that line, it is your display that needs to be replaced.
このアンサーは役に立ちましたか?
スコア 2
4 件のコメント:
Is this common because I have the same issue. I turned it on one day and it was just there.
さんによる 共有
@tmeverything heat and "high miles" are the most common causes for this. It is really not the screen itself but the components and solder on the driver boards. LCD screens are actually quite complex and sensitive.
さんによる 共有
Can GPU circuitry be fixed or is the laptop busted @oldturkey03 ?
さんによる 共有
@shanicecoleman it'll depend on the motherboard and which component has failed. Sometimes it's just a small SMD component that needs to be replaced and other times it is the GPU itself which might be difficult to replace.
さんによる 共有
コメントを追加
回答を追加する
Tanya Rey さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 868
