メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
18倍光学ズームおよび360倍デジタルズームを搭載したCanonのMiniDVビデオカメラ
How to fix the glitch camera
I have just bought a canon ZR60A, it works great but the camera somehow have glitches all over, it shows on the lcd screen and the viewfinder. When recording, it records exactly what the screen and the view finder displayed before, which mean the glitch comes from the camera itself, how can I handle this
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
@sangnguyen66374 you need to be more descriptive as to what kind of glitch. We do not know what you are referring to when you just use that term.
さんによる
Thanks, I've added the photo for a clearer point. I actually can still see the object, it's just that it has an extra layer of glitch and noise
さんによる
コメントを追加
1 件の回答
@sangnguyen66374 since it "records exactly what the screen and the view finder displayed" and it shows the menu but not what you are looking at, the error is most likely in the video circuitry and not coming from the CCD image sensor or even being an LCD error. Looks like IC903 on the LCD board is responsible for the LCD signal processing and drive. I would stay there with checking the circuit. Here is the Canon ZR 60 A Service Manual and you can use that to check the LCD PCB
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
So is it possible to find the replacement part if the problem coming from the cuircuit component error as you're referencing...
さんによる
@sangnguyen66374 I would look for an LCD PCB and see if that resolves it.
さんによる
コメントを追加
回答を追加する
sang nguyễn さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 10
今までの合計 391
