speaker not working properly?
Low and muffled sound coming from the speaker
Hi Mehmet,
If you look at the bottom of your phone, you should see a speaker grill.
Is it clogged? if there is dust or other debris blocking the grill it will lower your speaker's performance.
Let me know what you see, and we can take it from there :)
このアンサーは役に立ちましたか?
Dust is there
このアンサーは役に立ちましたか?
Use something like a pair of small tweezers or a needle to gently clean out the charging port. Please be careful of the metal contacts on either side of the plastic piece in the middle of the port. Scratching or otherwise damaging these could result in a loss of charging functionality
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 531
Speaker not working
A33 samsung
Deepu Flipper さんによる
