How to replace screen?
My screen went all black after someone replaced and I don’t like how they did and I was wondering if I could do it myself
Hi Alloy,
Luckily replacing the screen on the Nitro 5 is not too complicated!
Here is a link to a YouTube video that will show you how to do perform the replacement yourself: Acer Nitro 5 Screen replacement - YouTube
and here is a link to a replacement screen (You can also find them on eBay): Screen for acer NITRO 5 AN515-54 SERIES. Replacement Laptop LCD Screen (laptopscreen.com)
If you're comfortable going a step further, I would disconnect the Main battery which can be done by undoing the screws holding the bottom plate. This Will just lower the chances of the screen getting damaged during installation.
I hope this helps, let me know if you have any other questions :)
このアンサーは役に立ちましたか?
Please folks, translate this (portuguese to english):
O problema mais dificil que enfrento é distinguir se o problema está na tela ou no flat cable.
O notebook caiu de uma altura de 20cm...no primeiro momento, nada aconteceu, 4 dias depois começou a dar esse problema.
このアンサーは役に立ちましたか?
過去 24時間: 3
過去 7 日: 33
過去 30 日: 107
今までの合計 2,961
Never replace a screen without disconnecting both the battery and the charger first!
LaptopTechnician さんによる 共有
