メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Patagoniaのアウターウェアは体を寒冷時には温め、雨天の日にはドライに保ってくれます。修理の難易度は簡単な継接ぎ作業から複雑なバッフル作業まで様々です。
Zipper pulled away from the jacket
The zipper still works on the jacket but on one side of the zipper the material pulled away. Suggestions on how to fix it?
It seem like the seams lost their adhesive and just pulled away
Update (02/23/24)
画像
This is the only place that I can find it. But as you can see the zipper has pulled away from the seam
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
@logandunn Can you upload a picture of the problem? iFixitでの質問に画像を追加する方法
さんによる
I updated the original post to have the picture in it
さんによる
コメントを追加
1 件の回答
There are several adhesives suitable for fabric such as Loctite vinyl, fabric & plastic; E6000; Sew No More; or, Patch Attach which you might use. You might try taking two stiff wooden slats slightly longer than the length of the separation and two or (better) three clamps and, with the zipper open, spread a small amount of your chosen adhesive on the portion of the zipper that you want to adhere to the fabric (you don't want to put on so much adhesive that it squeezes out when you clamp it), put a wood slat on each side and clamp it all together. You can probably get away with using spring loaded squeeze clamps but you can use whatever clamps you have on hand.
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Oh, and if there is any old adhesive remaining on the separated area, you would want to do the best you can to remove it before making the repair. It's not obvious from your picture what kind of material you're working with so I hesitate to recommend a solvent. My go-to is acetone but I would be very cautious and try a tiny amount applied by the corner of a dried out alcohol pad. A product called Goo-Gone is probably safer than acetone and is also very good at removing adhesives.
さんによる
It also occurs to me that you might try contacting Patagonia and asking them if there is a particular adhesive that they would recommend.
さんによる
コメントを追加
回答を追加する
Logan Dunn さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 28
今までの合計 500
