Which cable is which?
Green with what? Red with what? What are the other cables near the green and red ones? Ground???
この質問は役に立ちましたか?
この質問は役に立ちましたか?
@silviurec you should have two set of wires. One set Red/Copper and the other set Green/Copper. Red wire is Right Speaker + and Coper is Right Speaker Gnd. Green wire is Left speaker + and copper is Left speaker ground.This is where you need to connect the wires to:
Left = Tip
Right = Ring
Ground = Sleeve Both of the Copper wires get soldered on that pin
Something that looks like this will work for your headphones.
img from here
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 5
過去 30 日: 25
今までの合計 244
