メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Xiaomi Poco F3は、リフレッシュレート120 Hz、タッチサンプリングレート360 Hzの6.67インチAMOLEDディスプレイを搭載しています。プロセッサにはSnapdragon 870 5Gを採用。2021年3月発売。
USB port data transfer not working
Kind of weird story, I have bought this used phone which looked like new, after about 3 days and some weird problems like signal loss it died. send it to warranty and instead of changing the phone they have offered repair and charged me money for it. anyway after repair I am able to charge the phone and fast charge is working but I don't have data connection. my friend is a mobile technician and he said he changed USB/daughter board and also reballed CPU and still it's not working but ye also said that data would work for a very short period and then stop working again.
also I have some experience repairing phones if it matters.
Any help would be very appreciated.
Thanks in advance
best regards.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
最も参考になった回答
Hi @zze76jg7jjvqoqg
When you connect the phone to a computer, is there a notification asking you to select the type of USB connection you want to use?
If not, I realize that you said that the USB daughterboard was replaced but maybe check the pins 30 and 32 in the 40 pin flex cable connector are OK
Here's an image from the schematics showing where the CC1 and CC2 pins (cable attachment and removal detection, receptacle/plug orientation detection, and current advertisement function) connect to as well as the resistors mentioned by the schematic i.e. R6501 1 and R6502 1.
画像
(click on image)
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
E A さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 32
今までの合計 647
