メインコンテンツにスキップ
Fix your Asus VivoBook X201E laptop with these DIY replacement part repair guides!
Why does my laptop often have a blue screen?
Mengapa laptop saya sering bluescreen?
Ketika adaptor dilepas dari laptop, akan muncul bluescreen, kemudian laptop akan restart terus menerus Ketika adaptor dilepas dari laptop, akan muncul bluescreen, kemudian laptop akan restart terus meneru
When the adapter is removed from the laptop, a blue screen will appear, then the laptop will restart continuously! When the adapter is removed from the laptop, a blue screen will appear, then the laptop will restart continuously!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
If it works with the adapter plugged in, then it sounds like a battery issue. If it does work with adapter, I would first run CHKDSK and SFC /SCANNOW to eliminate and drive and file corruption issues.
Then you can persue trying to see if you can get a better definition. But in the end, it is probably the battery.
Try starting it in safe mode and reducing screen brightness to a minimum. All this to reduce power draw to see if he battery can support less drain. It may, or may not. If it does, I think that would eliminate a problem with the laptop. If it does or does not, start with a new battery.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
amikristanto さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 40
