メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号はA1059もしくはA1099 / 20、40、60 GBハードドライブ / タッチ反応クリックホイール
How to bypass battery
Hello All.
first timer here, new to the fourm. I have an ipod 4th gen that i'm trying to fix. I would like to bypass the battery to do some troubleshooting. anyone have any tips on how to do this? I was just thinking on pluging in 3.3v from a breadboard powersupply to the battery input.
Thanks in advance to any input and tips.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
I'm not very familiar with the 4th gen but from what I've seen it seems the battery is a 3 pin? Black is ground red is positive and a third white or yellow wire is presumably some type of thermistor. I would try applying gnd to black and 3.7v to red on the motherboard, check if it powers on, if it doesn't then it expects a signal on the thermistor pin coming from the battery. On most phones you can get away with pulling the thermistor pin on the motherboard to GND essentially 'emulating' a thermistor, I suspect it would work similarly on the iPod
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
ksharp117 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 282
