メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Ninja Coffee Bar CF086は、43オンスのサーマルカラフェとAuto-iQワンタッチインテリジェンスを備えたコーヒーメーカーです。
Digital display not working
My digital display has stopped functioning and you can’t see the numbers anymore for setting the brewing time in morning. Any idea if parts can be ordered to replace the LED display on it instead of replacing the whole thing.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
The part you're looking for is probably the display unit, and I found a potential match here: SunnyLED Display. However, sourcing this part domestically poses a challenge. While it's available for direct purchase overseas, the long shipping duration could be a major inconvenience. If you're reliant on your coffee maker daily, this might not be the best route.
A creative workaround could be scouting for a non-functional coffee maker on platforms like eBay, OfferUp, or Facebook Marketplace. This way, you can harvest the display part. It's a more sustainable approach and might even save you some money!
Another idea would be to disassemble the coffee maker to gain access to the part itself and verify the part number matches the one I linked above. If it does, take it to a local repair shop that is skilled in microsoldering. They may have the right equipment to repair it for you. If it doesn't match what I linked, do a Google (or preferred search engine) search for the part number and see if any local sources come up. You can also try searching on eBay for that part number just in case.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
Coffeemomma さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 10
過去 30 日: 44
今までの合計 2,456
