How to teardown Dualsense charging station adapter?
Hey guys
my dual sense charging station making weird sound and i want to open it to check it but i have no clue how can u give some hint? i guess it does not have any screws at all.
@adrenalizeme These power supply cases are ultrasonically welded together. This means that the two sections of the plastic are hard to separate. You can separate the two halves of the case by strategically prying them apart or you can use a rotary tool (Dremel) with a cutting wheel attachment.
If you want to open the power supply without a rotary tool (recommended), see jayeff's answer to this question. This YouTube video may also be able to help you.
Let me know if you have any additional questions or concerns.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 15
今までの合計 71
