メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2022年10月に発売されたGoogleのスマートフォン、Pixel 7 Proの修理および分解情報。モデル番号GP4BCおよびGE2AEで識別可能。
Google Pixel 7 Pro screen flicker
Replaced a broken screen on the wife's Pixel 7 pro and it worked perfect for a few months . Now if she uses it longer then about 5 minutes straight she gets some crazy screen flicker and the screen will slowly almost white out . Trying to figure out what the next step is. Faulty screen? something else broken? Maybe a setting or program causing overheating of cpu ? any help would be appreciated
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
Hi Keenan,
I have to agree with @ihave0idea that it's likely your replacement screen has failed. Whether that's due to physical or liquid damage, or an inherent defect in the screen, you'll probably never know. If it was a genuine Google replacement part (like what you'd get if you bought it from iFixit), then I'd lean toward the defective part diagnosis myself, as I've noted a disturbing tendency for genuine Google parts to have an unacceptably high defect rate.
It would probably be worth your time to back up the phone and try restoring it to factory settings and see if that has any effect on the problem. If not then you're almost certainly looking at having to replace the screen yet again. Given that your screen is only a few months old, it might be worthwhile checking with the vendor on their warranty policy. For example, if you bought it from iFixit then it has a lifetime warranty and would be replaced if found defective. You can check with them by emailing support@ifixit.com.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Likely the screen was defective, suggest you get a new one
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
This is an important learning experience for DIY screen replacers. Keep your old screen if it isn't completely useless. You could now switch back to the old screen and see if it operates correctly. Possibly disassemble the phone and clean the connector to the display w/ isopropyl alcohol before getting a new one.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Keenan Dowker さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 28
今までの合計 1,225
