メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Yoga Slim 7 Proでマルチタスクをマスターしましょう。このスタイリッシュな14インチのウルトラスリムノートパソコンは、AMD Ryzen™ 5000シリーズモバイルプロセッサーによる超高速パフォーマンスに加え、美しいオプションのOLED 2.8Kディスプレイ、長時間持続するバッテリー駆動時間、そして一日を最大限に活用できるさまざまなスマート機能を備えています。
My Camera Stopped Working
My camera randomly stopped working and my system says it is not connected. I have tried several software solutions but I think I might need to open it up and reconnect something...where can I find a guide to doing this? Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
Hi @ombreviews
Here's the hardware maintenance manual for the laptop.
Go to p.66 to view the procedure to remove the camera.
If the cable connection seems OK and the camera module needs replacing search online for either 5C20X55554 or 5C20X55556 to find suppliers that suit you best.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
How can I check the connector on the motherboard? Before removing the screen or anything like that. I wasn't seeing anything in the manual for that. Thanks so much!
さんによる
@ombreviews
Not sure with your model but nowadays a lot of the connections between the camera/microphone in the lid and the motherboard is done by a USB connection between the motherboard's IO chipset and a USB controller in the camera/microphone module. The two data wires for the USB are in with the video cable and not a separate cable.
All you can do is check how many cables come from the lid to the motherboard. Most likely there'll be the WiFi antennas connected to the WLAN card and a video cable and that's all.
You would really need to have the schematics for the motherboard to know exactly how it is connected.
I couldn't find a free schematic download online but if the board model number is an NM-D231 then you can purchase it here and it will show the wiring details
さんによる
コメントを追加
回答を追加する
OMB Reviews さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 6
過去 30 日: 15
今までの合計 597
