Turn on iPad without battery
I bought a used iPad without battery inside, can I turn it on(at least apple logo)or view it in iTunes
この質問は役に立ちましたか?
この質問は役に立ちましたか?
SOLVED: How to run iPad without battery? - iPad 3G - iFixit
OPTIONS
iPad is designed to run with a battery, thus there’s no really easy solution for your need. Not sure if the system requires also a battery presence acknowledgement or it’s sufficient a component bridging, but unless you’re able to microsolder and have the necessary tools is not a very handy solution. If you have to find and pay someone doing the job you’d end up paying multiple batteries cost to get the job done. All in all I believe a battery replacement is the easiest and cheapest solution."
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 6
過去 30 日: 34
今までの合計 904
