メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Raspberry Pi 3 Model Bの修理情報。2016年2月発売。モデル:B。
Raspberry Pi 3B+: HDMI not working
Hi iFixers. I have a couple of Raspberry Pi 3B+ boards that are fully functional but don't detect and therefore don't show any picture over HDMI. It's not a software bug and the connector is fine. I'd appreciate any hints on what chip controls HDMI output on those boards - maybe I'd be able to replace it
Update (01/29/24)
After spending some time examining things around on the board I believe the fault might be due to the IC pictured below or the components to the right. Does anyone know what those are? Any hints would be greatly appreciated 🙌🏻
画像
画像
画像
Update (01/29/24)
And one more weird detail - on the marked pin I get around 3V on the faulty boards instead of around 1,1V on a healthy one - what might cause this? Is this still that HDMI05-CL02F3 chip?
画像
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
I wonder if LAN7515 C000 chip that controls USB and Ethernet on the Pi also related to HDMI 🤔. Any ideas would be greatly appreciated
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi @insympathy
According to the datasheet the IC only handles USB and Ethernet.
If possible, try tracing the connections back from the HDMI port and see what IC they connect to. Wondering if HDMI is incorporated in the main Broadcom SoC IC
このアンサーは役に立ちましたか?
スコア 2
10 件のコメント:
Hey, thanks for a hint - I already found that too.
Now the question is the following: Pi shows the graphical interface over VNC perfectly well, so my guess would be that graphical core does work. It's something between the SoC and the HDMI port that stops the party :)
さんによる
@insympathy
Don't know Raspberry that well but have you tried this
さんによる
Tried all of that, thanks, but sadly it seems that it definitely is a hardware issue
さんによる
@insympathy
You've probably already got this but perhaps check if there's 5V on pin 18 of the HDMI port
さんによる
You are absolutely right and I do get at least 4,7V on pin 18 :)
さんによる
5件以上のコメントを表示
コメントを追加
回答を追加する
in_sympathy さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 18
過去 30 日: 66
今までの合計 971
