Unfortunately, Bitlocker is designed to be a secure encryption system, and it is not possible to unlock a Bitlocker-encrypted drive without the correct recovery key or password. There are a ton of false promises for software online who want to steal your money.
The real answer is bitlocker is a anti brute force encryption system and you are not going to find tools in the wild to remove the password or let you access the data on the drive.
The only hope you have is to obtain the key through your friends nephew.
The drive can absolutely be formatted and used again you just are not going to get access to the data that currently exists.
Formatting Drive
1. Hit Win+R key, then type diskpart and press Enter.
2. Then input these commands below in turn:
- list disk
- select disk n, where the n stands for the disk you want to format.
- list partition
- select partition n, where the n stands for the encrypted hard drive you want to delete.
- delete partition override
Finally Type exit to close window. This will wipe all the data on the encrypted hard drive. Then you could create new partition on that drive again.
I hope this helps,
Cheers!!
Monte
1件のコメント
You can try to find help from a data recovery agency as they have professional tools such as PC3K, MRT, Atola, etc. that can directly remove the ATA password. If you want to try it yourself, you can use tools like zen. Note that trying it yourself may result in data loss.
Mittie Saglimbeni さんによる
