Why does my phone keep restarting
Keeps restarting every 3 minutes and says panic full cpu 3
This should help you read the panic log and diagnose the issue. https://www.youtube.com/watch?v=C2687jnf...
From what I've seen in my shop, the most common cause for a 3 minute restart is an issue with the charge port. Just be aware this piece of software isn't always accurate, and does require further diagnosis, it's a tool used to help narrow down what the issue could be.
このアンサーは役に立ちましたか?
iPhone 14 keep restarting if there's an issue with the wireless charging/rear mic/flash.
You can reproduce it by disconnecting the flex cable.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 18
今までの合計 391
post the full panic log
daniel さんによる
Well, probably don't need the full log, but at least the first page or so.
Jerry Wheeler さんによる
