Does my late 2011 17" A1927 have a 32 bit cpu?
My laptop has Catalina OS.
How is this possible?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
no, it has 64-bit cpu i7-2760QM https://www.intel.com/content/www/us/en/...
このアンサーは役に立ちましたか?
This is not correct! Review this listing to see what your given system has 17” MacBook Pro (A1297). This can be confusing as some in this series have a split CPU architecture. What it has internally and what it has externally are different review the Intel Core Duo 2 specs as far as the 2011/12 models (i5 & i7) they are 64Bit but the EFI firmware and the calls are 32Bit.
@danj Thank you for your advice
I am 72 yo & a late newbie after 40+ years in construction & remodeling.
I have elected to use the late 2011 A1297 series due to my failing eyesight.
That is why I have 3 laptops to ensure I have backup protection rather than spending more $ that I don't have on the latest models.
I bought the 1 laptop for $300 that has the Catalina OS but I don't know how it got done.
I need help to upgrade the 2 laptops with the same specs, so I can go forward secure in the knowledge that I can deal with the many mundane tasks that takes up 80% of my life
Thank you for your help.
@xmaslovechild - To be clear you have three of the same model (all are 2011 or 2012)? Is that correct?
@danj Yes, that is correct
@danj Are you as flummoxed as much as I am.
I thank you for what you have done up to this point.
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 89
1件のコメント
The CPU is either a i7-2760QM (2.4GHz) or a i7-2860QM (2.5GHz) both of which are Quad Core 64-bit Intel Mobile Core i7. Both also have a 64 bit EFI architecture
oldturkey03 さんによる
